[GRASS-user] Wich file format to "transport" (raster/ vector) datafrom a GRASSdb in to another computer's GRASS db? Why export vector data inshapefile for starspan/ OpenEV?
Patton, Eric epatton at nrcan.gc.ca
Mon Mar 10 14:23:09 EDT 2008
>1.. if one needs to copy some GRASS raster data from his data base in
>another computer's GRASS data base (same coordinate system of course),
>then how? Where do for example the history files go?
See r.pack/r.unpack in the Grass Add-ons. I use these scripts for moving
rasters around from computer to computer:
http://grass.gdf-hannover.de/wiki/GRASS_AddOns#Raster_add-ons
The r.pack script uses a MatLab format file as an intermediary, and is apparently
a decent universal format for storing rasters in.
>I understand (I think) the need to set-up properly a LOCATION and import
>the data. But why isn't there a GRASS portable vector/ raster file
>format?
I think r.in/out.ascii and v.in/out.ascii are designed for this? Not 100%
sure, but check the man pages for these two commands.
>2. the same about vector data
See above.
>3. Is it really necessaty to export in shapefiles when working with
>starspan? If there is "GRASS read-only" support by OGR why is it
>necessary to export?
I can't comment on Starspan; never used it.
>What about OpenEV? If GDAL is built with GRASS support why can't it read
>GRASS rasters?
I've wondered how to do this as well.
~ Eric.
