[GRASS-user] Unable to import some raster and vector type maps
Eric & Elga eegaba at terra.com.br
Tue Mar 11 15:06:16 EDT 2008
----- Original Message -----
From: "Marco Lechner" <marco.lechner at geographie.uni-freiburg.de>
To: "Nikos Alexandris" <nikos.alexandris at felis.uni-freiburg.de>
Cc: "Eric & Elga" <eegaba at terra.com.br>; <grass-user at lists.osgeo.org>
Sent: Tuesday, March 11, 2008 4:49 PM
Subject: Re: [GRASS-user] Unable to import some raster and vector type maps
> why not grabbing it from ftp://e0srp01u.ecs.nasa.gov/srtm/version2/SRTM3
> and using r.in.srtm directly?
> workflow:
> - r.in.srtm
> - r.null (may be not necessary, depends if NULL values are already set
> to NULL)
> - r.fillnulls (extensive but good spline interpolation to fill holes)
> Marco
> Nikos Alexandris schrieb:
> > On Tue, 2008-03-11 at 15:17 -0300, Eric & Elga wrote:
> >> Good afternoon.
> > Hi!
> >> After having created a new project location, I try to import SRTM3
> > About SRTM: I don't know from where you have your srtm data. You can
> > grab srtm3 tiles also from http://srtm.csi.cgiar.org/ (look for the SRTM
> > Data Search and Download link).
> > The data are provided in GeoTiFF and are projected in wgs84. So you need
> > to create a LOCATION for wgs84 and impot with r.in.gdal
> > (Make sure you select the "JRC" mirror to download the data if you are
> > in Europe, otherwhise it's slow).
@ nikos : The problem with CSI data is that they are not freely reusable : I
create maps, mostly topographic ones, as hobby for the Wikipedia community
where all media have to be placed under a free license, i.e. which can also
be used for commercial purpose.
@ Marco : These are the srtm and swbd I use but as I wrote, when I try to
launch r.in.srtm or v.in.e00 they crash before opening. I'm very new with
GRASS, is there another way to launch these modules? I'm running
wingrass6.3RC5 : could it be that these modules use the monitor which
doesn't work with this version?
Thanks.
Eric
