[GRASS-windows] Re: [GRASS-user] Xming as X server for winGRASS?
Fri Mar 14 15:19:36 EDT 2008
Moritz Lennert wrote:
> > echo %PATH% says:
> >     C:\msys\1.0\bin;C:\Perl\bin;
> > which I have set in the grass63.bat file.
> You need to add the above paths to the PATH variable, not replace all
> the contents of that variable with the above paths, i.e.
> set PATH=%PATH%;C:\msys\1.0\bin;C:\Perl\bin
I would recommend putting MSys' bin directory first, e.g.:
	set PATH=C:\msys\1.0\bin;%PATH%;C:\Perl\bin
The reason is that Windows has some programs with the same name as
common Unix programs (e.g. "find"), and scripts will want to use the
Unix versions.
