[GRASS-user] WinGRASS-6.3.0RC5 Self Installer + wxPython-Gui
Helmut Kudrnovsky hellik at web.de
Fri Mar 14 20:51:57 EDT 2008
hi,
i have a little time to test the new wingrass-6.3RC5.
great work!!!
is it possible to use new wxpython-gui with this RC?
from the README-file in the wxpython-directory:
    "2 - STARTUP WITH GRASS INITIALIZATION
      If you want to run wxPython GUI automatically when you start
      GRASS, edit your .grassrc6 file to replace
      GRASS_GUI: tcktk (or whatever you have here)
      with
      GRASS_GUI: wxpython
       or easier start new GRASS session with -wxpython switch.
      $ grass -wxpython
     3 - STARTUP FROM GRASS TERMINAL
      Simply type
      $ g.gui wxpython
      from the GRASS terminal.
      You can also specify workspace file to load on startup.
      $ g.gui gui=wxpython workspace=myworkspace.grc"
so first i start grass with tcltk-gui from the short-cut-panel "Programme-> GRASS -> GRASS 6.3 RC5", then i put the following command
            g.gui -u gui=wxpython
and the output of g.gisenv is:
            GISDBASE='C:/gis_sampledata';
            LOCATION_NAME='spearfish60';
            MAPSET='user1';
            GRASS_GUI='wxpython';
and seems to be ok.
then i start grass again from the short-cut-panel "Programme-> GRASS -> GRASS 6.3 RC5", but the tcltk-gui is starting again.
so i tried the second way to start the wx-gui with an additional line in .grassrc6
the location of  .grassrc6 is "C:\GRASS\msys\home\Dokumente und Einstellungen\helli\.grassrc6"
but nothing has changed, tcltk-gui started again.
how can i start and test the new wxpython-gui on windows? maybe are there problems with the spaces in the path to .grassrc6
my system:
win xp - german version
python 2.4
wxPython 2.8.7.
wingrass-6.3.RC5
best regards
helli
_____________________________________________________________________
Unbegrenzter Speicherplatz für Ihr E-Mail Postfach? Jetzt aktivieren!
http://freemail.web.de/club/landingpage.htm/?mc=025555
