[GRASS-user] WinGRASS-6.3.0RC5 Self Installer + wxPython-Gui
Martin Landa landa.martin at gmail.com
Sat Mar 15 06:57:40 EDT 2008
Hi Helmut,
I have fixed wxPython GUI code to work also under MS Windows (only
basic functionality without digitizer). For RC6 or final 6.3.0 wxGUI
should be functional also under MS Windows. For now you can try to
compile GRASS from trunk or releasebranch_6_3 on MS Windows on your
own.
see
http://grass.gdf-hannover.de/wiki/WxPython-based_GUI_for_GRASS#MS_Windows
Martin
2008/3/15, Helmut Kudrnovsky <hellik at web.de>:
> hi,
>  a short update.
>  i tried also to start grass with the wxpython-gui within the msys-environment, and there is the following out-message:
>  "helli at LUPO /home/Dokumente und Einstellungen/helli
>  $ grass63 -wxpython
>  WELCOME TO GRASS              Version 6.3.0RC5         2008
>    1) Have at your side all available GRASS tutorials
>    2) When working on your location, the following materials
>       are extremely useful:
>       - A topo map of your area
>       - Current catalog of available computer maps
>    3) Check the GRASS webpages for feedback mailinglists and more:
>       http://www.grass-gis.org
>       http://grass.osgeo.org
>  Hit RETURN to continue
>  Starting GRASS ...
>  /C/GRASS/etc/Init.sh: python: command not found
>  ERROR: Invalid return code from gis_set.tcl.
>  Please advise GRASS developers of this error.
>  WARNING: Attention!
>  WARNING: Locking is not supported on Windows!
>  GRASS GUI should be wxpython
>  /C/GRASS/etc/wxpython/scripts/wxgui: python: command not found
>           __________  ___   __________    _______________
>          / ____/ __ \/   | / ___/ ___/   / ____/  _/ ___/
>         / / __/ /_/ / /| | \__ \\_  \   / / __ / / \__ \
>        / /_/ / _, _/ ___ |___/ /__/ /  / /_/ // / ___/ /
>        \____/_/ |_/_/  |_/____/____/   \____/___//____/
>  Welcome to GRASS 6.3.0RC5 (2008)
>  GRASS homepage:                          http://grass.osgeo.org/
>  This version running thru:               Bourne Shell (/bin/sh)
>  Help is available with the command:      g.manual -i
>  See the licence terms with:              g.version -c
>  If required, restart the GUI with:       g.gui wxpython
>  When ready to quit enter:                exit
>  GRASS 6.3.0RC5 (<UNKNOWN>):C:/GRASS/msys/home/Dokumente und Einstellungen/helli >"
>  maybe this helps to sort out the problem
>  best regards
>  helli
>  _____________________________________________________________________
>  Der WEB.DE SmartSurfer hilft bis zu 70% Ihrer Onlinekosten zu sparen!
>  http://smartsurfer.web.de/?mc=100071&distributionid=000000000066
>  grass-user mailing list
>  grass-user at lists.osgeo.org
>  http://lists.osgeo.org/mailman/listinfo/grass-user
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
