[GRASS-user] r.shaded.relief strangeness
Mon Mar 17 20:22:15 EDT 2008
Patton, Eric wrote:
> >Not sure if this is very critical, but I have noticed a problem with
> >r.shaded.relief. If the region is set to 10m and then a shaded rel. map is
> >produced from a 30m input data, a corrupt map is produced.
> >example with spearfish data:
> ># set region, and force 10m resolution
> >g.region rast=elevation.10m -p
> I assume you meant g.region rast=elevation.10m res=10 -ap ?
> ># compute shaded rel. map from 30m res data:
> ># see image [1]
> >r.shaded.relief map=elevation.dem shade=shade
> I can't reproduce this. I can produce a Moire-patterned shaded-relief map,
> since I didn't resample the 30m data to 10m:
> Try r.resample first?
r.resample won't help. That uses libgis' built-in nearest-neighbour
resampling, so you will get exactly the same result as with using the
lower resolution map.
Using r.resamp.interp with method=bilinear or method=bicubic should
eliminate the problems with generating slope and aspect maps.
