[GRASS-user] WinGRASS-6.3.0RC5 Self Installer + wxPython-Gui
Helmut Kudrnovsky hellik at web.de
Tue Mar 18 04:34:20 EDT 2008
hi,
>Glynn Clements glynn at gclements.plus.com
>Tue Mar 18 04:03:09 EDT 2008
>Helmut Kudrnovsky wrote:
>> but during the make-process a lot of error-messages-pop-ups, especially for the vector
>> modules come up .
>> english-translation from a german error-message:
>> "v.segment.exe could not be found - the application could not be started, because libpq.dll was not found."
>You need to add the directory where the DLLs reside to the PATH
>setting. Or copy the DLLs to the dist.<arch>/lib directory (or to
>Windows' System32 directory).
i will try the above later
>FWIW, the above errors relate to building the HTML documentation, but
>you'll get similar errors when running the programs.
the html-documentation is built properly in C:\msys\1.0\local\grass-6.3.svn\docs\html. what should be wrong?
>> but the output from the make-process seems to be ok:
>> Following modules are missing the 'description.html' file in src code:
>> GRASS GIS compilation log
>> Started compilation: Mon Mar 17 22:33:14 GMT 2008
>> Errors in:
>> /local/src/grasssvntrunk/imagery/i.class
>> /local/src/grasssvntrunk/imagery/i.ortho.photo/photo.2image
>> /local/src/grasssvntrunk/imagery/i.ortho.photo/photo.2target
>> /local/src/grasssvntrunk/imagery/i.ortho.photo/photo.rectify
>> /local/src/grasssvntrunk/imagery/i.points
>> /local/src/grasssvntrunk/imagery/i.vpoints
>> /local/src/grasssvntrunk/raster/r.li/r.li.daemon
>> /local/src/grasssvntrunk/raster/r.li/r.li.edgedensity
>> /local/src/grasssvntrunk/raster/r.li/r.li.patchdensity
>> /local/src/grasssvntrunk/raster/r.li/r.li.patchnum
>> /local/src/grasssvntrunk/raster/r.li/r.li.shape
>> /local/src/grasssvntrunk/raster/r.li/r.li.simpson
>> /local/src/grasssvntrunk/raster/r.li/r.li.shannon
>> /local/src/grasssvntrunk/raster/r.li/r.li.mps
>> /local/src/grasssvntrunk/raster/r.li/r.li.mpa
>> /local/src/grasssvntrunk/raster/r.li/r.li.padcv
>> /local/src/grasssvntrunk/raster/r.li/r.li.padsd
>> /local/src/grasssvntrunk/raster/r.li/r.li.padrange
>> /local/src/grasssvntrunk/raster/r.li/r.li.cwed
>> /local/src/grasssvntrunk/raster/r.li/r.li.richness
>> /local/src/grasssvntrunk/raster/r.li/r.li.dominance
>The above modules are all known not to compile on Windows.
ok
>Glynn Clements <glynn at gclements.plus.com>
best regards
helli
_____________________________________________________________________
Der WEB.DE SmartSurfer hilft bis zu 70% Ihrer Onlinekosten zu sparen!
http://smartsurfer.web.de/?mc=100071&distributionid=000000000066
