[GRASS-user] vrml import to grass
Hamish hamish_b at yahoo.com
Tue Mar 18 21:20:26 EDT 2008
Maciej Tomaszczyk wrote:
> i am wonder if is a way to import wrml file in to the GRASS.
> There is v.out.vrml but i cant find any command to import this type of
> file.
not directly, but I see there is a project called "geomview" which can
convert VRML to RenderMan RIB, maybe that gets you closer or you can find
something that converts from RIB to something GDAL knows?
Worse come to worse the VRML format is known and you could write
something to dump the data to an ascii file.
Hamish
      ____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile.  Try it now.  http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
