[GRASS-user] r.in.xyz
Wed Mar 19 00:25:33 EDT 2008
Edmondo Elisei wrote:
> 1) My r.in.xyz command line:
> r.in.xyz input=/grassdata/archivio_vettoriale/_subset_points.txt
> output=subset method=mean type=FCELL fs=, x=1 y=2 z=3 percent=100
> 2) g.region -p result:
> projection: 1 (UTM)
> zone:       33
> datum:      eur50
> ellipsoid:  international
> north:      4478400.26
> south:      4477190.36
> west:       654486.51
> east:       655494.12
> nsres:      0.99991736
> ewres:      0.9996131
> rows:       1210
> cols:       1008
> cells:      1219680
> 3) the r.in.xyz procedure ends with message:
> "r.in.xyz complete. 1184 points found in region"
Import the points file as a vector map with v.in.ascii then generate a
raster map with v.surf.rst.
