[GRASS-user] Re: [GRASS-dev] Re: another r.resamp.interp bug report
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Wed Mar 19 09:23:04 EDT 2008
On Tue, 2008-03-18 at 21:49 -0700, Michael Barton wrote:
> On Mar 18, 2008, at 9:39 PM, Helena Mitasova wrote:
> > Michael - I have added an example from the book at the bottom of
> > this page - please try it and let me know whether it works.
> > http://skagit.meas.ncsu.edu/~helena/grasswork/grassbookdat07/
> > ncexternal/demo.txt
> > Please keep in mind that r.resample* is for reinterpolation of
> > continuous data to a different resolution not for interpolation
> > from scattered data (see the equations in the Appendix on what it
> > does)  (r.surf.idw is designed for scattered data input in raster
> > format). You should convert your points from raster to vector
> > points and use the v.surf* modules to interpolate.
> > I hope this helps and let me know if the examples don't work
Thanks. It's clear now.
> Thanks Helena. The issue that I ran into today (embarrassingly with
> my class) is that of the v.surf.*modules, v.surf.bspline does not
> work (I reported this sometime back), v.surf.rst crashes and brings
> down the entire GUI (this is new), leaving only v.surf.idw as the
> only functional interpolation routine in todays SVN trunk.
> Michael
Michael, just out of curiousity: is your initial input data vector
(points) or raster (scattered pixels)?
Thank you in advance,
Nikos
