[GRASS-user] first littel experience with wxpython GUI
Martin Landa landa.martin at gmail.com
Thu Mar 20 08:41:32 EDT 2008
2008/3/20, Dr. Manuel Seeger <seeger at uni-trier.de>:
>  GRASS 6.3.svn (Attert_Praktikum):~ > ERROR: MAPSET Anne - permission denied
These errors are not GUI-related, you have simply no access to this
mapset. I will fix wxGUI not to crash. In any case you need to set up
permissions if you want to access this mapset.
Martin
>  GRASS_INFO_ERROR(497,1): MAPSET Anne - permission denied
>  GRASS_INFO_END(497,1)
>  Traceback (most recent call last):
>   File "/usr/local/grass-6.3.svn/etc/wxpython/wxgui.py", line 1360, in
>  <module>
>     sys.exit(main())
>   File "/usr/local/grass-6.3.svn/etc/wxpython/wxgui.py", line 1353, in main
>     app = GMApp(workspaceFile)
>   File "/usr/local/grass-6.3.svn/etc/wxpython/wxgui.py", line 1275, in
>  __init__
>     wx.App.__init__(self, False)
>   File
>  "/usr/lib/python2.5/site-packages/wx-2.8-gtk2-unicode/wx/_core.py", line
>  7836, in __init__
>     self._BootstrapApp()
>   File
>  7433, in _BootstrapApp
>     return _core_.PyApp__BootstrapApp(*args, **kwargs)
>   File "/usr/local/grass-6.3.svn/etc/wxpython/wxgui.py", line 1291, in
>  OnInit
>     workspace = self.workspaceFile)
>   File "/usr/local/grass-6.3.svn/etc/wxpython/wxgui.py", line 157, in
>  __init__
>     self.NewDisplay(show=False)
>   File "/usr/local/grass-6.3.svn/etc/wxpython/wxgui.py", line 1027, in
>  NewDisplay
>     auimgr=self._auimgr, showMapDisplay=show)
>   File
>  "/usr/local/grass-6.3.svn/etc/wxpython/gui_modules/wxgui_utils.py", line
>  77, in __init__
>     self.Map = render.Map()    # instance of render.Map to be associated
>  with display
>   File "/usr/local/grass-6.3.svn/etc/wxpython/gui_modules/render.py",
>  line 201, in __init__
>     self.mapfile   = utils.GetTempfile()
>   File "/usr/local/grass-6.3.svn/etc/wxpython/gui_modules/utils.py",
>  line 41, in GetTempfile
>     "pid=%d" % os.getpid()])
>   File "/usr/local/grass-6.3.svn/etc/wxpython/gui_modules/gcmd.py", line
>  361, in __init__
>     self.PrintModuleOutput()))
>  gui_modules.gcmd.CmdError
>  Greetings
>  Manuel
>  Martin Landa schrieb:
> > Hi,
>  > 2008/3/18, Dr. Manuel Seeger <seeger at uni-trier.de>:
>  > [snip]
>  >>  wxpython shows all mapsets present, but then crashes when I try to
>  >>  access those which were created by another user. I did not see any
>  > [snip]
>  > It seems to work on my laptop, can you send me error message, traceback?
>  > Martin
> _______________________________________________________________________
>  Dr. Manuel Seeger
>  Wiss. Assistent                         Scientific Assistant
>  Physische Geographie                    Dpt. of Physical Geography
>  FB VI - Geographie/Geowissenschaften    Geography/Geosciences
>  Universität Trier                       University of Trier
>  D - 54286 Trier
>  Tel.:   +49-651-201 4557
>  Fax:    +49-651-201 3976
>  Web:    http://www-neu.uni-trier.de/index.php?id=9607
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
