[GRASS-user] first littel experience with wxpython GUI
Dr. Manuel Seeger seeger at uni-trier.de
Thu Mar 20 09:19:17 EDT 2008
Hi Martin,
the mapset was generated by another user. so i have read, but not write
access, when I am in grass (command line or gis.m).
So my suggestion was to identify somehow within the start window the
files where i might have write access. So there would be no problem when
starting grass -wxpython. as it is eg. at the gis.m, wher you sinply do
no see the mapsets where you do not have write access (later on, within
grass they'r accessible)
Thanks and best regards!
Manuel
Martin Landa schrieb:
> Hi,
> 2008/3/20, Dr. Manuel Seeger <seeger at uni-trier.de>:
>>  GRASS 6.3.svn (Attert_Praktikum):~ > ERROR: MAPSET Anne - permission denied
> These errors are not GUI-related, you have simply no access to this
> mapset. I will fix wxGUI not to crash. In any case you need to set up
> permissions if you want to access this mapset.
> Martin
>>  GRASS_INFO_ERROR(497,1): MAPSET Anne - permission denied
>>  GRASS_INFO_END(497,1)
>>  Traceback (most recent call last):
>>   File "/usr/local/grass-6.3.svn/etc/wxpython/wxgui.py", line 1360, in
>>  <module>
>>     sys.exit(main())
>>   File "/usr/local/grass-6.3.svn/etc/wxpython/wxgui.py", line 1353, in main
>>     app = GMApp(workspaceFile)
>>   File "/usr/local/grass-6.3.svn/etc/wxpython/wxgui.py", line 1275, in
>>  __init__
>>     wx.App.__init__(self, False)
>>   File
>>  "/usr/lib/python2.5/site-packages/wx-2.8-gtk2-unicode/wx/_core.py", line
>>  7836, in __init__
>>     self._BootstrapApp()
>>   File
>>  7433, in _BootstrapApp
>>     return _core_.PyApp__BootstrapApp(*args, **kwargs)
>>   File "/usr/local/grass-6.3.svn/etc/wxpython/wxgui.py", line 1291, in
>>  OnInit
>>     workspace = self.workspaceFile)
>>   File "/usr/local/grass-6.3.svn/etc/wxpython/wxgui.py", line 157, in
>>  __init__
>>     self.NewDisplay(show=False)
>>   File "/usr/local/grass-6.3.svn/etc/wxpython/wxgui.py", line 1027, in
>>  NewDisplay
>>     auimgr=self._auimgr, showMapDisplay=show)
>>   File
>>  "/usr/local/grass-6.3.svn/etc/wxpython/gui_modules/wxgui_utils.py", line
>>  77, in __init__
>>     self.Map = render.Map()    # instance of render.Map to be associated
>>  with display
>>   File "/usr/local/grass-6.3.svn/etc/wxpython/gui_modules/render.py",
>>  line 201, in __init__
>>     self.mapfile   = utils.GetTempfile()
>>   File "/usr/local/grass-6.3.svn/etc/wxpython/gui_modules/utils.py",
>>  line 41, in GetTempfile
>>     "pid=%d" % os.getpid()])
>>   File "/usr/local/grass-6.3.svn/etc/wxpython/gui_modules/gcmd.py", line
>>  361, in __init__
>>     self.PrintModuleOutput()))
>>  gui_modules.gcmd.CmdError
>>  Greetings
>>  Manuel
>>> Hi,
>>  > 2008/3/18, Dr. Manuel Seeger <seeger at uni-trier.de>:
>>  > [snip]
>>  >>  wxpython shows all mapsets present, but then crashes when I try to
>>  >>  access those which were created by another user. I did not see any
>>  > [snip]
>>  > It seems to work on my laptop, can you send me error message, traceback?
>>  > Martin
>> _______________________________________________________________________
>>  Dr. Manuel Seeger
>>  Wiss. Assistent                         Scientific Assistant
>>  Physische Geographie                    Dpt. of Physical Geography
>>  FB VI - Geographie/Geowissenschaften    Geography/Geosciences
>>  Universität Trier                       University of Trier
>>  D - 54286 Trier
>>  Tel.:   +49-651-201 4557
>>  Fax:    +49-651-201 3976
>>  Web:    http://www-neu.uni-trier.de/index.php?id=9607
Dr. Manuel Seeger
D - 54286 Trier
