[GRASS-user] How to find intersection of two lines
Jarek Jasiewicz jarekj at amu.edu.pl
Thu Mar 20 12:15:49 EDT 2008
Moritz Lennert wrote:
> On 20/03/08 11:17, Jarosław Jasiewicz wrote:
>> Hi I have lots of raster, thinned lines and second raster with with
>> one line. I must find all points where second line intersect with
>> lines on first raster
>> it is very simple:
>> r.mapcalc points=if(raster_two==1&&raster_one==1,1,null())
>> but there is one exception:
>> AB
>> BA
>> when lines intersect with 45 grades. There is intersection but
>> without common point. Naither buffor nor grow is not a solution
>> because I need exactly one point lying exactly on line from raster one
>> Any Ideas
> Either ressample your rasters to coarser resolution to make them
> coincide, or convert to vector and use a combination of v.patch +
> v.clean (e.g. v.clean input=lines1 output=lines2 err=points tool=break)
> Moritz
thanks for ansfer
I tried it with similar way (v.patch +v.clean + topology report) but it
is not it. I need EXACT coordinates of pixels on intersection do to
transfer it to another program
I soleved problem with r.to.vect and detailed corecting line manualy on
problematic areas, little more work but result as I expected.
Jarek
