[GRASS-user] GRASS 6.3.0RC5
Hamish hamish_b at yahoo.com
Wed Mar 26 07:33:46 EDT 2008
> RAVI KUMAR wrote:
> > BUG:
> > using spearfish57 roads data for Net work analysis
Markus wrote:
> native winGRASS does not have support for X11, I assume
> that you tried d.path which isn't supported AFAIK.
FWIW d.path has the coor= parameter which lets it run non-interactively.
No idea if that means it will compile, but I would guess stuff could be
#ifdef'd into allowing it to run.
or maybe it is this part: "The user needs to display a vector map before
using d.path." But if map= was given it shouldn't need to worry about the
Xmon at all?
Hamish
      ____________________________________________________________________________________
Looking for last minute shopping deals?
Find them fast with Yahoo! Search.  http://tools.search.yahoo.com/newsearch/category.php?category=shopping
