[GRASS-user] modify feature's values interactively
Martin Landa landa.martin at gmail.com
Wed Mar 26 11:17:00 EDT 2008
2008/3/26, christian Brandt <chrisbrandt74 at hotmail.com>:
> is it possible within GRASS to modify feature's values (of the feature
> attribute table) interactively (e.g. like in ArcGIS, where I can select an
> object within the view which then can be modified/removed...)?
you mean to modify attribute data of vector objects? If so, yes, you
can use v.digit or digitizer in wxPython GUI (experimental).
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
