[GRASS-user] modify feature's values interactively
Martin Landa landa.martin at gmail.com
Thu Mar 27 06:04:09 EDT 2008
2008/3/27, Moritz Lennert <mlennert at club.worldonline.be>:
[snip]
>  However, I just can't get it to work:
>  I have
>  GRASS 6.3.svn (spearfish60):~ > v.db.connect -p roads
>  Vector map <roads at PERMANENT> is connected by:
>  layer <1> table <roads> in database
>  </home/mlennert/GRASS/DATA/spearfish60/PERMANENT/dbf/> through driver
>  <dbf> with key <cat>
>  Querying in display mode works as expected:
>  East: 596271.961722
>  North: 4924483.851675
>  Map: roads
>  Mapset: PERMANENT
>  Type: Line
>  Line: 51
>  Longueur: 1416.211362
>  couche: 1
>  catégorie: 3
>  Driver: dbf
>  Database: /home/mlennert/GRASS/DATA/spearfish60/PERMANENT/dbf/
>  Table: roads
>  Key column: cat
>  cat : 3
>  label : secondary highway, hard surface
>  But when I try to query it in edit mode, I get:
>  "No database record available"
strange, I used for testing also 'roads' from spearfish60, seems to work.
>  Also: probably the button's properties should be changed so that you can
>  click on it again directly to change from one mode to the other.
>  Currently you have to click on another button and then back on the query
>  button to change mode.
You don't need to change a tool, double-click on 'query' should show menu again.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
