[GRASS-user] Building a new module
Fri Mar 28 15:29:34 EDT 2008
roberto caselli wrote:
> I have to build a new module for GRASS, but I have some doubts about
> what the things I have to do.
> First of all, i'd need some data structure like graphs, union finds
> and dynamic trees. Are these structure included in GRASS?
Generally, you need to provide your own data structures and associated
algorithms. There is a btree library, but that's about it.
However, as GRASS is licensed under the GPL (version 2 or later), you
can use code from other GPL or GPL-compatible (LGPL, MIT, new BSD
licences) software.
> For a beginner like me a guide that explains the building of a module
> (or a pattern) would be very very helpful. Could you suggest me
> something to ease my work?
The usual approach is to find a similar module and use that as a
template.
