[GRASS-user] Connect additional dbf file based on layer 1 attribute column
Luigi Ponti lponti at infinito.it
Mon Mar 31 10:04:41 EDT 2008
Dear list,
I am trying to import the European Vector Database (ESDB) version 2 to
GRASS -- original data is ArcInfo shapefile. Maybe most of you already
know about this freely downloadable database, but for those who don't:
http://eusoils.jrc.ec.europa.eu/Library/ESDAC/Online_Data.cfm
Well, the main ESDB shapefile layer name is called sgdbe4_0, which comes
in the usual .shp, .prj, .shx, and .dbf extensions. The sgdbe4_0 layer
gets imported OK via v.in.ogr, but most of the soil database is left out
of the new GRASS vector, because it is included in additional .dbf files
with different names, which are therefore not imported into the new
GRASS vector.
The sgdbe4_0.dbf table in the GRASS vector has at least one attribute
column in common with the other additional .dbf files that don't get
imported. Is it possible to connect those .dbf files to the imported
GRASS vector based on an attribute column (not the 'cat' column) that is
present both in layer 1 of the vector and in those additional (not
connected) .dbf files?
Thanks and regards,
Luigi
[GRASS 6.2 - Cygwin]
