[GRASS-user] mosaic with landsat geotiff
Maciej Sieczka tutey at o2.pl
Fri May 9 03:10:52 EDT 2008
Juan Manuel Barreneche pisze:
> [These images come labeled by the orbit
> of the satellite and the "point", which is the number of image of the
> sequence of said orbit, and are in UTM projection (resolution 30m x
> 30m)]
Juan,
Different UTM zones are different coordinate systems. If you want to
uses data form two different UTM zones you need to reproject them into a
common coordinate system first. Finding such a system is up to you.
Reprojection can be accomplished with gdalwarp. If you need to do it in
GRASS there is r.proj.
Maciek
