[GRASS-user] calculating slope in SRTM data from http://srtm.csi.cgiar.org/
maning sambale emmanuel.sambale at gmail.com
Fri May 9 04:24:14 EDT 2008
I'm using processed SRTM data from http://srtm.csi.cgiar.org/ the
current release is Version 3, which was a great improvement from V1
and 2 especially with 1/2 pixel shift, coastline boundary clipping and
filled holes.
I would like to ask others on using this dataset in calculating slope.
 I now have  a working GRASS database with SRTM imported (as integer).
 In running r.slope.aspect, do I need to do further pre-processing of
the SRTM DEM? The 90m pixel size is OK for the purpose of the
research.
cheers,
maning
| __.-._ |"Ohhh. Great warrior. Wars not make one great." -Yoda |
| '-._"7' |"Freedom is still the most radical idea of all" -N.Branden|
| /'.-c |Linux registered user #402901, http://counter.li.org/ |
| | /T |http://esambale.wikispaces.com|
| _)_/LI
