[GRASS-user] Use GRASS as a web-application?
G. Allegri giohappy at gmail.com
Sat May 10 06:26:14 EDT 2008
Also, take a look to the "Recent Earthquakes: map generated by GRASS on the
fly with PHP" example:
http://grass.itc.it/spearfish/php_grass_earthquakes.php
Giovanni
2008/5/10 Paul Kelly <paul-grass at stjohnspoint.co.uk>:
> On Sat, 10 May 2008, Jachym Cepicky wrote:
>  Hi,
>> http://pywps.wald.intevation.org is here for this purpose
>> if you prefer java, look after 52north wps implementation
> Also, GRASS-links at http://pnwpest.org/glinks/ is a much older
> implementation that was somewhat ahead of its time - probably only of
> interest for historical reference purposes but it seems to still work. I'm
> not sure which version of GRASS that demo implementation runs on but I
> suspect it is 4.x. It might be updateable to use more recent versions
> though. Depends on what you need I suppose.
> Paul
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080510/7762e34a/attachment.html
