[GRASS-user] batch import/sql shapefiles
maning sambale emmanuel.sambale at gmail.com
Tue May 13 06:37:52 EDT 2008
Wolf,
Aha!  It works now!
Salamat!
maning
On Tue, May 13, 2008 at 5:59 PM, Wolf Bergenheim
<wolf+grass at bergenheim.net> wrote:
> On 13.05.2008 10:52, maning sambale wrote:
> > Hi,
> > This simple script doesn't seem to work on my cygwin bash
> > for i in *.shp; do
> >        ogr2ogr -f "ESRI Shapefile" -where "ELEVATION>10" $i_elev $i;
> > done
>  You have two errors:
>  1) (as Hamish pointed out) $i_elev is a legal variable name so you want
> {$i}_elev
>  2) {i}_elev will become shapefile.shp_elev, which ogr2ogr might have a
> problem with..
>  so instead try: $i_elev ==> elev_$i
>  --Wolf
>  <:3 )---- Wolf Bergenheim ----( 8:>
| __.-._ |"Ohhh. Great warrior. Wars not make one great." -Yoda |
| '-._"7' |"Freedom is still the most radical idea of all" -N.Branden|
| /'.-c |Linux registered user #402901, http://counter.li.org/ |
| | /T |http://esambale.wikispaces.com|
| _)_/LI
