[GRASS-user] grass error on ubuntu hardy amd64
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Tue May 13 15:21:13 EDT 2008
On Tue, 2008-05-13 at 21:48 +0300, Rosca Bogdan wrote:
> Hi!
> I have installed Ubuntu Hardy and Grass63. When I tried to start with
> my mapset I get an error: "Error setting region (Problem with
> g.region?) child process exited abnormally". I should mention that in
> Windows platform I have open my mapset, so that's nothing wrong with
> my data.
> I am trying to migrate to linux, so I am new in this field, but I want
> to benefit from my amd64 capabilities. Please help
> Roscao
Hi Roscao.
Did you use Jachym's debs? Or did you install from Ubuntu repositories?
Just try to set the computational region using one of your datasets (I
suppose you already have something inside) with:
>g.region rast=SOMERASTER
or
>g.region vect=SOMEVECT
If I did not understand your problem correctly and you can't even get
into the GRASS shell why don't you try to create a LOCATION using (for
example) an already georeferenced file and try to start.
Cheers,
Nikos
