[GRASS-user] Vdigit
Martin Landa landa.martin at gmail.com
Wed May 14 10:51:52 EDT 2008
2008/5/14 Benoit ANDRE <benoit.andre at bcgeol.be>:
>  Since 6-3.0.RC06, no more possible to compile vdigit.  The error message is
which version of swig you are using?
swig -version
Martin
>  .[benoit at slump vdigit]$ make
>  c++
> -I/disques/linux-1/archive/GIS/grass/grass-6.4/cvn/grass-6.4.svn_src_snapshot_2008_05_10/dist.i686-pc-linux-gnu/include
> -g -O2   -fPIC -I/usr/local/include -I/usr/local/include/python2.5
> -I/usr/local/include/python2.5 -fno-strict-aliasing -DNDEBUG -g -fwrapv -O3
> -Wall -Wstrict-prototypes -I/usr/local/lib/wx/include/gtk2-unicode-debug-2.8
> -I/usr/local/include/wx-2.8 -D_FILE_OFFSET_BITS=64 -D_LARGE_FILES
> -D__WXDEBUG__ -D__WXGTK__ -pthread   -DPACKAGE=\""grasslibs"\"
> -o OBJ.i686-pc-linux-gnu/grass6_wxvdigit_wrap.o -c grass6_wxvdigit_wrap.cpp
>  cc1plus: attention : l'option de la ligne de commande "-Wstrict-prototypes"
> est valide pour Ada/C/ObjC mais pas pour C++
>  grass6_wxvdigit_wrap.cpp: In function 'int
> SWIG_Python_ConvertFunctionPtr(PyObject*, void**, swig_type_info*)':
>  grass6_wxvdigit_wrap.cpp:2051: erreur: invalid conversion from 'const
> char*' to 'char*'
>  grass6_wxvdigit_wrap.cpp: In function 'void
> SWIG_Python_FixMethods(PyMethodDef*, swig_const_info*, swig_type_info**,
> swig_type_info**)':
>  grass6_wxvdigit_wrap.cpp:12866: erreur: invalid conversion from 'const
> char*' to 'char*'
>  make: *** [OBJ.i686-pc-linux-gnu/grass6_wxvdigit_wrap.o] Erreur 1
>  The links /usr/local/lib/libgdi.so to
> /usr/lib/python2.4/site-packages/wx-2.8-gtk2-unicode/wx/_gdi_.so is good.
>  I tried with various installations of wxWidget (enable or disable debug,
> enable or disable share), without success.  Any idea ?
>  Benoit ANDRE
>  Géologue - Hydrologue ________________________________
>  Bureau Conseil en Géologie
>  Rue de Leuze, 433
>  B-5300 VEZIN
>  BELGIQUE
>  Tél.: +32 81 58 26 11
>  Fax.: +32 81 58 26 12
>  Contacter...
>  Bureau Conseil en Géologie ________________________________
>  grass-user mailing list
>  grass-user at lists.osgeo.org
>  http://lists.osgeo.org/mailman/listinfo/grass-user
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
