[GRASS-user] GRASS Setup Win
Hamish hamish_b at yahoo.com
Mon May 19 06:21:29 EDT 2008
> But I still find that V.Net.Path requires the coordinates
> of two end points to be in a 'File' for input to
> get the shortest path between these points.
yes
> In your last mail I had a notion that you indicated that
> the points can be 'Mouse Input', for V.Net.Path.
d.path's default is to take input from the mouse, but there is a new option to use the coordinates from coor= instead, when interactive mouse is not there (native Windows).
d.path and v.net.path are different code which do similar things.
Hamish
