[GRASS-user] Weird Cygwin -Grass 6.2.3 issues
Manuel Francisco Maestre Páez mfmap at tragsatec.es
Mon May 19 09:44:19 EDT 2008
Thanks again.
I've tried moving that two libraries to c:/cygwin/bin and "cygchecking" all
executables in /usr/local/bin . All of them seems ok but i got the same
results (i mean, nothing). The exit code is still the same too (128).
I keep on trying... Never give up!
P.D.
This the result of cygcheck now:
$ cygcheck /usr/local/bin/cyggdal-1.dll
C:\cygwin\usr/local/bin/cyggdal-1.dll
  C:\cygwin\bin\cygwin1.dll
    C:\WINDOWS\System32\ADVAPI32.DLL
      C:\WINDOWS\System32\ntdll.dll
      C:\WINDOWS\System32\KERNEL32.dll
      C:\WINDOWS\System32\RPCRT4.dll
  C:\cygwin\bin\cygjasper-1-701-1.dll
    C:\cygwin\bin\cygjpeg-62.dll
  C:\cygwin\bin\cygpng12.dll
    C:\cygwin\bin\cygz.dll
  C:\cygwin\bin\cygpq.dll
    C:\cygwin\bin\cygcrypt-0.dll
    C:\cygwin\bin\cygcrypto-0.9.8.dll
    C:\cygwin\bin\cygintl-3.dll
      C:\cygwin\bin\cygiconv-2.dll
    C:\cygwin\bin\cygssl-0.9.8.dll
  C:\cygwin\bin\cygtiff-5.dll
All gdal executables are giving the same cygcheck output.
-----Glynn Clements <glynn en gclements.plus.com> escribió: -----
Para: "Manuel Francisco Maestre Páez" <mfmap en tragsatec.es>
De: Glynn Clements <glynn en gclements.plus.com>
Fecha: 19/05/2008 14:22
cc: grass-user <grass-user en lists.osgeo.org>
Asunto: Re: [GRASS-user] Weird Cygwin -Grass 6.2.3 issues
Manuel Francisco Maestre Páez wrote:
> Thanks for the answer, but i tried checking cyggdal-1.dll and it seems
it's
> all ok.
> I have installed all the libraries you said (and some more just in case)
i
> tried different versions for some of them, but... still no luck.
> What can it be? I'm getting frustrated `_´
>   C:\WINDOWS\System32\cygjasper-1-701-1.dll
>     C:\WINDOWS\System32\cygcrypto-0.9.8.dll
The fact that cygjasper-1-701-1.dll and cygcrypto-0.9.8.dll are in
C:\WINDOWS\System32 isn't encouraging. Cygwin-specific DLLs shouldn't
exist anywhere outside of C:\cygwin.
Also, you could try running cygcheck on the executables themselves,
e.g. gdalinfo etc.
