[GRASS-user] Error using v.rast.stats script in cigwin and wingrass
Hamish hamish_b at yahoo.com
Wed May 21 01:55:12 EDT 2008
> > maning sambale:
> >> Using v.rast.stats in grass6.3 both in cygwin and
> >> native windows,
> >> v.rast.stats vector=myupland_lowland at allah_valley
> >>   layer=1 raster=allah_dem at allah_valley colprefix=dem
> >>   percentile=90
> >> I get this error
> >> :/GRASS/scripts/v.rast.stats: r.cats: command not found
> >> I see no entry in the 6.3 manual on r.cats
> >> any ideas on using v.rast.stats?
Hamish:
> > Are you using the official 6.3.0 or an old SVN
> > snapshot? I though this was fixed for 6.3.0.
> > r.cats was renamed r.category, and (with 6.3.0) there
> > should be a r.cats script which calls r.category.
> > Before the script there was a symlink (alias)
> > for it, but that didn't work so well with MSys and
> > so was replaced with the forwarding script.
> > since then v.rast.stats has been updated to use the
> > new name.
maning:
> from
> http://grass.ibiblio.org/grass63/binary/mswindows/cygwin/
> downloaded last 2008/05/08
> According to the site
> grass-6.3.0-2.cygwin.tar.bz2 22-Apr-2008 10:09   20M
> So the packages are 22 of April.
hmmm, don't know. the r.cats script should be there- it was included in the release source code:
http://trac.osgeo.org/grass/browser/grass/tags/release_20080423_grass_6_3_0_1/scripts/r.cats
oh well. the easiest solution is to edit the v.rast.stats script in a text editor to rename it, as seen here:
  http://trac.osgeo.org/grass/changeset/31306
(maybe do the edit in something more advanced than notepad - something that can handle UNIX newlines. e.g. TextPad, or nedit in Cygwin)
Hamish
