R: [GRASS-user] gps import: definition of WGS84
Marco Pasetti marco.pasetti at alice.it
Fri May 23 17:11:41 EDT 2008
Hi all,
In settings -> options -> projection, try to set "prompt for projection" and
select the desired projection (define a custum one, if you prefer) every
time you import points (or whatever) using gpsbabel. Probably you set to use
a projection (different from the one defined with gpsbabel) as standard
projection for every "import" in the current project. Actually I'm not sure
about it, but just try, it could work :-)
Marco
