[GRASS-user] Trouble with v.db.join and sqlite
Luca Casagrande luca.casagrande at gmail.com
Mon May 26 03:22:31 EDT 2008
Hello everybody.
I am working with 6.4svn (built yesterday) and got some troubles with
v.db.join and sqlite.
If I try to run the command, this is the error reported:
 v.db.join map=aste_geologia at aste_geologia column=link otable=reticolo
ocolumn=link
DBMI-SQLite driver error:
Error in sqlite3_prepare():
duplicate column name: cat
ERROR: Error while executing: 'ALTER TABLE aste_geologia ADD COLUMN cat
INTEGER
ERROR: Cannot continue (problem adding column).
ERROR: Cannot continue.
If I try to remove the column cat by hand ( as suggested in a post in the ml),
it goes fine:
GRASS 6.4.svn (wrme):~ > db.dropcol -f aste_geo_bak colum=cat
Forcing ...
WARNING: Deleting <cat> column which may be needed to keep table connected
         to a vector map
Any idea?
Thank you very much
Luca
