[GRASS-user] Re: d.split.frame
Hamish hamish_b at yahoo.com
Mon May 26 22:31:45 EDT 2008
> Salutations from Freiburg to all ;-)
Greetings from sunny Dunedin,
> How do I "integrate" the d.frame.split script in grass63.1.svn,
> so I don't need to call it from within its directory?
put addons scripts in a dir someplace, then before you start GRASS set the GRASS_ADDON_PATH environment variable.
e.g. put this in ~/.bashrc:
 export GRASS_ADDON_PATH=/home/you/grass/addons
Hamish
