[GRASS-user] Triangles polygons with Arc*
Daniel Victoria daniel.victoria at gmail.com
Tue May 27 09:24:35 EDT 2008
Well, maybe Arc is smoothing those 3 pixels...
On Tue, May 27, 2008 at 12:07 AM, maning sambale
<emmanuel.sambale at gmail.com> wrote:
> Hi,
> Hi,
> Just curious if anybody encountered this issue with Arc*:
> When converting raster to vector using ArcGIS/View triangular polygons
> are generated especially with small areas (1-3 pixels from the
> original raster).
> See image:
> http://farm3.static.flickr.com/2127/2510680112_25cc16686e.jpg
> I think I made a similar thing before (using ArcGIS "Hydro
> extension").  Is this correct?
> As far as I'm concerned, the output should be regular polygon blocks
> since raster grid is the input.  Unless in GRASS, you use the -s flag
> of r.to.vect
> maning
> | __.-._ |"Ohhh. Great warrior. Wars not make one great." -Yoda |
> | '-._"7' |"Freedom is still the most radical idea of all" -N.Branden|
> | /'.-c |Linux registered user #402901, http://counter.li.org/ |
> | | /T |http://esambale.wikispaces.com|
> | _)_/LI
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
