[GRASS-user] help
Patton, Eric epatton at nrcan.gc.ca
Wed May 28 10:24:19 EDT 2008
>thank you a lot, im new in grass, im learning and i cant get the poligon
>area, i think the procedure is to use the boundary button, make it close
>then use the centroid option and then when i save the file and check the
>info it says i  have a boundary and a centriod but no area, im i missing
>some steps?
>my snapping is the same as yours
Please keep all responses on the Grass mailing list so that others may
participate/respond. Thanks...
Can you post a screenshot of your v.digit session? What happens when you manually
move two vertices together, do they snap? Can you post the output from v.info?
~ Eric.
