[GRASS-user] segmentation fault r.li on 6.3.1svn (subject errata corrige)
Markus Neteler neteler at osgeo.org
Wed May 28 16:19:37 EDT 2008
For the list record:
I could reproduce the problem with long file/path names on their
machine. Buffer lengths are now corrected and the problem
apparently fixed (6.3.svn, 6.4.svn and 7.trunk).
Markus
On Thu, May 22, 2008 at 12:31 AM, Markus Neteler <neteler at osgeo.org> wrote:
> Hi Leo,
> I have tested with your data which you sent offlist to me in GRASS 6.4.svn:
> no problem - works.
> Markus
> On Wed, May 21, 2008 at 12:02 PM, Leonardo Lami <lami at faunalia.it> wrote:
>> Hi all,
>> I'm testing r.li.x on 6.3.1svn but I have some problems.
>> I run r.li.setup setting a moving windows 60x60 cells in a region with a
>> resolution 5x5 meters as sampling area. The region have this values:
>> projection: 99 (Transverse Mercator)
>> zone:       0
>> datum:      rome40
>> ellipsoid:  a=6378388 es=0.006722670022333322
>> north:      4817400
>> south:      4812130
>> west:       1644645
>> east:       1651180
>> nsres:      5
>> ewres:      5
>> rows:       1054
>> cols:       1307
>> cells:      1377578
>> The sampling area file have this contenents:
>> SAMPLINGFRAME 0|0|1|1
>> SAMPLEAREA -1|-1|0.0569259962049|0.0459066564652
>> MOVINGWINDOW
>> When I run r.li.shannon I have this output:
>> GRASS 6.3.1svn (Toscana):~ > r.li.shannon
>> map=uso_primavera_2005 at mipi_analisi conf=vicarello
>> output=uso_primavera_2005_vicarello_shannon
>> [5]+  Done                    r.li.setup
>> Segmentation fault
>> WARNING: Can't open header file for [uso_primavera_2005 in (null)]
>> CHILD[pid = 6124]: unable to open 2+ mask ... continue without!!!
>> GRASS 6.3.1svn (Toscana):~ > WARNING: Can't open header file for
>> CHILD[pid = 6123]: unable to open 2+ mask ... continue without!!!
>> CHILD[pid = 6122]: unable to open 2+ mask ... continue without!!!
>> CHILD[pid = 6121]: unable to open 2+ mask ... continue without!!!
>> CHILD[pid = 6120]: unable to open 2+ mask ... continue without!!!
>> CHILD[pid = 6119]: unable to open 2+ mask ... continue without!!!
>> CHILD[pid = 6118]: unable to open 2+ mask ... continue without!!!
>> CHILD[pid = 6117]: unable to open 2+ mask ... continue without!!!
>> CHILD[pid = 6116]: unable to open 2+ mask ... continue without!!!
>> CHILD[pid = 6115]: unable to open 2+ mask ... continue without!!!
>> The problem seems to be in the header raster file...but it doesn't seem
>> particular strange:
>> proj:       99
>> zone:       0
>> north:      4817400
>> south:      4812130
>> east:       1651180
>> west:       1644645
>> cols:       1307
>> rows:       1054
>> e-w resol:  5
>> n-s resol:  5
>> format:     2
>> compressed: 1
>> Have someone any ideas?
>> Thank you very much for your help!
>> Leonardo
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> Open Source Geospatial Foundation
> http://www.osgeo.org/
> http://www.grassbook.org/
