[GRASS-user] RST - how does it chooses from near points?
Carlos "Guâno" Grohmann carlos.grohmann at gmail.com
Sat May 31 15:53:35 EDT 2008
This is Helena's answer:
> Carlos,
>  first point found at a given location is preserved and any consequent
> points within distance smaller than dmin are ignored (the z-values are
> not taken into account). I have done some experiments with 3D distance as
> well if you need to take into account the z - it is very easy to change
> that in the code but that would require adding a flag and I am not sure
> that many users would need it.
> If your data are contours, use v.generalize to "thin" the points first -
> it speeds up the processing a lot and the results are much better - see
> here:
> http://skagit.meas.ncsu.edu/~helena/grasswork/interpgen.html
> If you want to use mean value of your close points - the best approach is
> through r.in.xyz - see the example in its man page
> Helena
cheers
On Wed, May 28, 2008 at 5:19 AM, Markus Neteler <neteler at osgeo.org> wrote:
> Maybe best ask to Helena who is on the road and not subscribed
> to this list AFAIK...
> please post the answer then!
> markus
> On Tue, May 27, 2008 at 9:39 PM, Carlos Guâno Grohmann
> <carlos.grohmann at gmail.com> wrote:
>> It just came to me: if I have a vector map to be interpolated by RST,
>> how does the algorithm chooses between points that are very close to
>> each other?
>> And if I have more than one point with the same coordinates, but
>> different values?
>> thks all
>> Carlos
>>  Carlos Henrique Grohmann - Guano
>>  Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
>> Linux User #89721 - carlos dot grohmann at gmail dot com
>> _________________
>> "Good morning, doctors. I have taken the liberty of removing Windows
>> 95 from my hard drive."
>> --The winning entry in a "What were HAL's first words" contest judged
>> by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
>> Can't stop the signal.
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> Open Source Geospatial Foundation
> http://www.osgeo.org/
> http://www.grassbook.org/
_________________
