[GRASS-user] using grass on rasters without converting?
Sat Nov 1 00:29:10 EDT 2008
Markus Neteler wrote:
> >> > I'm not too familiar with the WMS driver.  But if it doesn't support
> >> > skipping rows then it is a bug and should be fixed.  To file a ticket on
> >> > this issue it would be helpful if a demonstration of the problem could
> >> > be boiled down to a small C/C++ program or Python script just depending
> >> > on GDAL.
> >> > Adam Nowaki is the main author of the WMS driver.
> >> Unfortunately I am not skilled enough in Python to write down the
> >> requested test case.
> > Does "gdal_translate -outsize ..." work with WMS?
> Apparently not:
> gdal_translate -outsize 20% 20% wms_jpl_onearth.xml bla.tif
> Input file size is 2666666, 1333333
> 0
> ... then it goes into poll time-out (according to strace).
In that case, it's a GDAL issue, and that should be a sufficient test
case.
