[GRASS-user] using grass on rasters without converting?
Markus Neteler neteler at osgeo.org
Sat Nov 1 02:10:13 EDT 2008
On Sat, Nov 1, 2008 at 5:29 AM, Glynn Clements <glynn at gclements.plus.com> wrote:
> Markus Neteler wrote:
>> >> > I'm not too familiar with the WMS driver.  But if it doesn't support
>> >> > skipping rows then it is a bug and should be fixed.  To file a ticket on
>> >> > this issue it would be helpful if a demonstration of the problem could
>> >> > be boiled down to a small C/C++ program or Python script just depending
>> >> > on GDAL.
>> >> > Adam Nowaki is the main author of the WMS driver.
>> >> Unfortunately I am not skilled enough in Python to write down the
>> >> requested test case.
>> > Does "gdal_translate -outsize ..." work with WMS?
>> Apparently not:
>> gdal_translate -outsize 20% 20% wms_jpl_onearth.xml bla.tif
>> Input file size is 2666666, 1333333
>> 0
>> ... then it goes into poll time-out (according to strace).
> In that case, it's a GDAL issue, and that should be a sufficient test
> case.
Right. Filed as
http://trac.osgeo.org/gdal/ticket/264
Markus
