A solution? (including resolution) - Re: [GRASS-user] Re: Help: Converting a raster map between locations (from wgs84 lat / long to UTM)
Corrado ct529 at york.ac.uk
Mon Nov 3 07:10:20 EST 2008
Dear friends,
this is what I have done:
1) created a location test12, coordinate system “latitude – longitude”, wgs84
datum, default datum transformation parameters (1), region 90N,60S
(=-60) ,180W (=-180),180E, resolution 30 seconds (=0.00833333 degrees) on
both the X and y axis.
2) imported the file: r.in.bin -s bytes=2 input=prec/prec_4.bil north=90N
south=60S west=180W east=180E output=dummy01 rows=18000 cols=43200
anull=-9999
3) selected the region of interest: g.region n=64N s=49N w=10W e=2E
4) calculated the width of the 30 seconds raster pixel, using the command
g.region -m:
<snippet>
n=64
s=49
w=-10
e=2
nsres=927.90359439
ewres=508.14568663
rows=1800
cols=1440
</snippet>
5) created the region box, using the command:
v.in.region output=region_box
6) created a new location, test13, using UTM, osgb36 datum, (1) datum
transformation parameters (5 m resolution), zone 30, region 1300000
(N),-200000 (S), -800000(W),800000(E), resolution 1 m.
7) loaded the region box:
v.proj input=region_box location=test12 mapset=PERMANENT
output=region_box_fromtest12
8) set the region to the region identified by the vector:
g.region vect=region_box_fromtest12
9) set the resolution to the resolution calculated previously:
g.region nsres=927.90359439 ewres=508.14568663
10) project the raster file:
r.proj input=dummy01 location=test12 mapset=PERMANENT
output=test_fromtest12_02 method=cubic
11) set the resolution I want:
g.region nsres=2000 ewres=2000
12) resample:
r.resample input=test_fromtest12_02
output=test_fromtest12_02_resample --overwrite
What do you think?
On Saturday 01 November 2008 04:33:55 Glynn Clements wrote:
> Sebastian P. Luque wrote:
> > On an "additional" question: How do people set the resolution
> > correctly when transforming from lat/lon to meter and vice-versa?
> There is no "correct" resolution when re-projecting rasters; whatever
> you choose, the conversion will be "lossy" to some extent. It's just a
> question of what's adequate for your purposes.
Corrado Topi
Global Climate Change & Biodiversity Indicators
Area 18,Department of Biology
University of York, York, YO10 5YW, UK
Phone: + 44 (0) 1904 328645, E-mail: ct529 at york.ac.uk
