[GRASS-user] Rename multiple sqlite columns at once
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Mon Nov 3 11:11:37 EST 2008
On Mon, 2008-11-03 at 16:58 +0100, Nikos Alexandris wrote:
> Is there (hopefully?) any way to translate for example all Caps to lower
> case letters in all column names of a vector maps attribute tavble
> (stored in sqlite.db)?
> Any way to apply similar techniques like with common GNU text utilities
> (i.e. tr, sed, cut)?
> Kind regards, Nikos
The command
v.db.renamecol map=test_rencol column="AREA","area"
does not work. I assume that trying to use 'tr' for example wouldn't
help (?). Or am I doing something wrong?
