[GRASS-user] Exporting raster map into unusual ascii file
Dylan Beaudette dylan.beaudette at gmail.com
Wed Nov 5 11:45:46 EST 2008
On Wednesday 05 November 2008, Corrado wrote:
> Dear friends,
> I have some 36 raster maps in one location, in the mapset PERMANENT: 12 for
> the average monthly precipitation, 12 for the min temperature, 12 for the
> max temperature. They are on the same region at the same resolution, with
> nsres = ewres (2000).
> I would like to ouput (export) them into a text (CSV) file in the format:
> coordinate X, coordinate Y, value from map 1, ....., value from map 36
> is that possible? if it is possible, how?
> Thanks!
check out r.stats (?)  I think that you can output a single column of x,y,z
data for each map, then use a combination of paste and cut to "horizonatally
stack" the set of files into a new file.
make sense?
Dylan
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
