[GRASS-user] resampling and patching DEM
Wed Nov 5 17:15:24 EST 2008
Silvia Simoni wrote:
> I need to patch dems with different resolutions (1x1m) and (2x2 m) and
> resample them to a coarser resolution (10x10 m). Which is the correct
> procedure?
> a. resampling the 1x1 dem to 2x2 using r.resampl.stats -w (to be more
> accurate)
> patch them all at 2x2, resample the patched dem to 10x10m;
> b.resample the 1x1 and 2x2 dem to 10x10 m separately using
> r.resampl.stats -w, and then patch them all.
In most cases, the most accurate approach is to set the region to 1x1,
patch (which will resample everything to 1x1 by nearest-neighbour),
then resample to 10x10 with r.resamp.stats.
The problem with patching down-sampled data is that r.patch won't
merge partial results at the boundaries. It will simply discard choose
one value and discard the others.
