[GRASS-user] saving log for a script
Daniel Victoria daniel.victoria at gmail.com
Thu Nov 6 10:46:59 EST 2008
Hi Milton,
If your script is in bash (using MSys Console), check out the tee
command and > (grater then sign). With those you can redirect output
to a file so
ls *.tif > lista_tif.txt
will create a file lista_tif.txt with the output from the command ls *.tif
If you want to append something to the file use 2 >, that is
ls *.tif >> lista_tif.txt
will put the ls command output to the end of the already created file
Cheers
Daniel
On Thu, Nov 6, 2008 at 12:32 PM, Milton Cezar Ribeiro
<miltinho.astronauta at gmail.com> wrote:
> Dear ALL,
> I am running a script on native WinGRASS.
> I would like to save a log of all processing steps and system comments.
> How can I direct the log to an external file? I would like to include on
> the script the starting time/date and finishing time/date. Any help are
> welcome.
> Best regards
> miltinho astronauta
> brazil
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
