[GRASS-user] Rename multiple sqlite columns at once
Moritz Lennert mlennert at club.worldonline.be
Thu Nov 6 19:38:01 EST 2008
On 06/11/08 20:33, Nikos Alexandris wrote:
> On Thu, 2008-11-06 at 19:59 +0100, Moritz Lennert wrote:
>>> # output
>>> block_id\_tmp
>> I think this is because of the quotes:
>> tempcolumn="$tempcolumn""\_tmp"
>> But actually, trying out your entire original script, I don't see
>> where
>> the problem is. The attached version seems to work perfectly for me
>> (just slightly simplified from your original version):
>> What exactly did not work when you tried this ?
>> Moritz
> Moritz,
> thank you for your time.
> 1. I *corrected* the double quotes and re-run the script. [Script +
> output attached]
You still use quotes:
tempcolumn="$tempcolumn\_tmp"
IIUC, the quotes will let the slash appear literally. So, just leave out
the quotes as follows:
tempcolumn=$tempcolumn\_tmp
However, as you say your original script (in my modified form) actually
worked, it just spit out a series of warnings. So it might be more
interesting to check upon these warnings. I only saw these with the
sqlite driver, not with dbf or postgresql, so we should try to find out
what happens  with that driver.
Moritz
> 2. I tried your latest script (the one you attached in the previous
> message). It works but I still get those column-type-related WARNINGS.
> [Script + output attached]
> Kind Regards, Nikos
> # I *corrected* the tempcolumn="$tempcolumn""\_tmp"
> ## Actually it didn't work in first place this is why I experimented a bit by adding the double quotes!
> cat caps_2_lower_moritzx.sh -n
>      1	#!/bin/sh -x
>      2
>      3	key_column="cat"
>      4	suffix="_tmp"
>      5	for column in `db.columns test`; do
>      6	        if [ "$column" != "$key_column" ]; then
>      7	                tempcolumn=`echo $column | awk '{print tolower($1)}'`
>      8	                tempcolumn="$tempcolumn\_tmp"
>      9			echo $tempcolumn
>     10	                v.db.renamecol map=befliegung_copy column=$column,$tempcolumn
>     11			lower_column=`echo $tempcolumn $suffix | awk '{print
>     12	substr($1,1,length($1)-length($2))}'`
>     13	                v.db.renamecol map=test layer=1 column=$tempcolumn,$lower_column
>     14	        fi
>     15	done
>     16
>     17	db.columns test
> # Output when running the above
> sh ./caps_2_lower_moritzx.sh > caps_2_lower_moritzx2
> ERROR: Column <block_id> not found in table
> Sorry <_tmp> is not a valid option
> Description:
>  Renames a column in the attribute table connected to a given vector map.
> Keywords:
>  vector, database, attribute table
> Usage:
>  v.db.renamecol map=name [layer=value] column=string[,string,...]
>    [--verbose] [--quiet]
> Flags:
>  --v   Verbose module output
>  --q   Quiet module output
> Parameters:
>      map   Vector map for which to rename attribute column
>    layer   Layer where to rename column
>            default: 1
>   column   Old and new name of the column (old,new)
> ERROR: Column <AREA> not found in table
> Description:
> Keywords:
> Usage:
> Flags:
> Parameters:
>            default: 1
> ERROR: Column <PERIMETER> not found in table
> Description:
> Keywords:
> Usage:
> Flags:
> Parameters:
>            default: 1
> ERROR: Column <RAS2X2_> not found in table
> Description:
> Keywords:
> Usage:
> Flags:
> Parameters:
>            default: 1
> ERROR: Column <RAS2X2_ID> not found in table
> Description:
> Keywords:
> Usage:
> Flags:
> Parameters:
>            default: 1
> ERROR: Column <RAS2X2_NR> not found in table
> Description:
> Keywords:
> Usage:
> Flags:
> Parameters:
>            default: 1
> ERROR: Column <block> not found in table
> Description:
> Keywords:
> Usage:
> Flags:
> Parameters:
>            default: 1
> ERROR: Column <STAND> not found in table
> Description:
> Keywords:
> Usage:
> Flags:
> Parameters:
>            default: 1
> ERROR: Column <BEFL_DATUM> not found in table
> Description:
> Keywords:
> Usage:
> Flags:
> Parameters:
>            default: 1
> ERROR: Column <BEFL_JAHR> not found in table
> Description:
> Keywords:
> Usage:
> Flags:
> Parameters:
>            default: 1
> ERROR: Column <QUALITAET> not found in table
> Description:
> Keywords:
> Usage:
> Flags:
> Parameters:
>            default: 1
> [Raster MASK present]
> # Moritz's script...
> cat change_case.sh -n
>      1	#!/bin/sh -x
>      2
>      3	key_column="cat"
>      4	suffix="_tmp"
>      5	map="test"
>      6	for column in `db.columns test`; do
>      7	     if [ "$column" != "$key_column" ]; then
>      8	        tempcolumn=$column$suffix
>      9	        echo $tempcolumn
>     10	        v.db.renamecol map=$map column=$column,$tempcolumn
>     11		lowercolumn=`echo $column | awk '{print tolower($1)}'`
>     12	        v.db.renamecol map=$map layer=1 column=$tempcolumn,$lowercolumn
>     13	     fi
>     14	done
>     15
>     16	db.columns test
> # running the above works but I still get some WARNINGS... ??
> sh ./change_case.sh
> block_id_tmp
> AREA_tmp
> PERIMETER_tmp
> RAS2X2__tmp
> RAS2X2_ID_tmp
> RAS2X2_NR_tmp
> block_tmp
> WARNING: SQLite driver: unable to parse decltype: CHARACTER INTEGER
> WARNING: SQLite driver: column 'block_tmp', SQLite type 1 is not supported
> ERROR: Column <block_tmp> not found in table
> STAND_tmp
> BEFL_DATUM_tmp
> BEFL_JAHR_tmp
> QUALITAET_tmp
> cat
> block_id
> area
> perimeter
> ras2x2_
> ras2x2_id
> ras2x2_nr
> stand
> befl_datum
> befl_jahr
> qualitaet
