[GRASS-user] Re: v.in.ascii howto
Seb
spluque at gmail.com
Sat Nov 8 00:13:46 EST 2008
Never mind, I was misunderstanding that the "standard mode" in the man
page is actually the standard format, so passing format=standard is
what's needed in this case.
On Fri, 07 Nov 2008 22:30:37 -0600,
"Sebastian P. Luque" <spluque at gmail.com> wrote:
> Hi, How should one import an ASCII file which begins with:
> ORGANIZATION: DIGIT DATE: DIGIT NAME: MAP NAME: MAP DATE:
> MAP SCALE: 1 OTHER INFO: ZONE: 0 WEST EDGE:
> -360.000000 EAST EDGE: 360.000000 SOUTH EDGE: -90.000000 NORTH
> EDGE: 90.000000 MAP THRESH: 0.0001 VERTI: L 1435084 2 XXX.XXXXXX
> XX.XXXXXX .......... .........
> Essentially example 1a in the man page for v.in.ascii, which
> unfortunately doesn't have a command to show how this should be
> imported. Any advice would be appreciated. Thanks.
Seb
