[GRASS-user] v.mkgrid - segmentation fault
Paolo Craveri pcraveri at gmail.com
Sun Nov 9 16:55:34 EST 2008
 Hi all,
I get this error when I try to make a vector grid:
g.region -dp
projection: 0 (x,y)
zone: 0
north: 12
south: 0
west: 0
east: 12
nsres: 1
ewres: 1
rows: 12
cols: 12
cells: 144
v.mkgrid map=vectgrid grid=12,12 position=coor coor=0,0 box=1,1
Segmentation fault
v.info vgrid
ERROR: Unable to open vector map <vgrid at user1> on level 2. Try to rebuild
vector topology by v.build.
v.build vectgrid
WARNING: Coor files of vector map <vectgrid at user1> is larger than it should
be (14 bytes excess)
Building topology for vector map <vectgrid>...
0 primitives registered
0 vertices registered
0 areas built
0 isles built
Attaching islands:
Attaching centroids: Topology was built
Number of nodes : 0
Number of primitives: 0
Number of points : 0
Number of lines : 0
Number of boundaries: 0
Number of centroids : 0
Number of areas : 0
Number of isles : 0
I'm using GRASS 6.4.svn in Ubuntu 8.10.
What's wrong ?
Cheers,
Paolo
