[GRASS-user] v.net.iso - node costs
Paolo Craveri
pcraveri at gmail.com
Tue Nov 11 09:31:47 EST 2008
Hi all
how can I use v.net.iso with node costs ?
I tried this:
g.copy vect=roads,myroads,archsites,myarchsites --o
v.net myroads points=myarchsites out=mynetwork op=connect thresh=1000 --o
v.db.addtable mynetwork layer=2 col="cat integer, cost double precision"
echo "update mynetwork_2 set cost=1" | db.execute
v.net.iso in=mynetwork out=isocost alayer=1 nlayer=2 ncolumn=cost
ccats=1-10 cost=200,600,800,1200,5000 --o
and I get this error:
ERROR: Vect_read_line(): feature id -384 is not reasonable (max features in
vector map <mynetwork at user1>: 900)
No error I found if I omit ncolumn option (calculus without node costs).
Thank you,
Paolo
