[GRASS-user] gdal-grass plugin
Jarek Jasiewicz jarekj at amu.edu.pl
Tue Nov 11 14:11:36 EST 2008
yes I'm little unclear
Problem is with new qis ( G_no_gisinit error) I found on goolge solution
that I must recompile gdal without grass, next compile grass and grass
plugin
The question is:
I I'd like to install grass-plugin and latest version I found on:
http://www.gdal.org/dl/  is 1.4.3
so:
1) I can install gdal-grass plugin 1.4.3 on gdal 1.5.3
2) I must downgrade gdal to 1.4.3 (seems rather stupid idea)
3) there are is gdal-grass plugin 1.5.3 on the other locacation differ
than http://www.gdal.org/dl/
I ask because I have working gdal-grass instalation and I dont want to
destroy it.
Hope I'm clear
Jarek
Nikos Alexandris pisze:
> On Tue, 2008-11-11 at 18:38 +0100, Jarek Jasiewicz wrote:
>> Hi
> Hi Jarek!
>> Sorry for maybe naive question, but I'm little confused...
>> I have latest gdal 1.5.3 and compiled with grass but it makes problem
>> with qgis installtion
> What kind of problem?
>>  If I want to install gdall without grass and next install grass plugin
>> as is sugested:
>> http://grass.osgeo.org/wiki/Compile_and_install_GRASS_and_QGIS_with_GDAL/OGR_Plugin
>> which version of gdal sholud I use : the latest stable (still 1.5.3) or
>> donwgrade it to compatybile with latest plugin 1.4.3
> I always use gdal_stable (under Ubuntu 64-bit) and works fine.
>> greetings
>> Jarek
> Regards, Nikos
