[GRASS-user] why v.patch -e produces cat column starting from 2?
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Wed Nov 12 09:05:42 EST 2008
On Wed, 2008-11-12 at 14:44 +0100, Nikos Alexandris wrote:
> On Wed, 2008-11-12 at 05:35 +0100, Nikos Alexandris wrote:
> > Why isn't the cat column starting from 1 after (v.)patching vector maps
> > (whose cat's start normally from 1)? Is it that my maps have somethig
> > wrong? Is there a specific reason?
Following up with a WORKING example using "v.patch -a"
g.copy vect=block_trier,blocks --o
# using -a flag
v.patch -a input="block_daun" output="blocks" --o
# head of blocks is what I expect: cat(s) start with 1 :-)
db.select blocks | head -5
# clean I guess is necessary when features overlap eachother.
v.clean blocks tool=break,snap,rmdupl,rmdac thres=1,1,1 out=blocks_clean
My question(s) about why does "v.patch -e" remain :-)
Kind regards, Nikos
