[GRASS-user] 2 important broken wiki-links
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Wed Nov 12 16:47:43 EST 2008
Thank you Markus
On Wed, 2008-11-12 at 22:39 +0100, Markus Neteler wrote:
> Try in the main source code directory:
> make htmldocs-single
> it should build also the Vector_Library docs (lib/vector/) but on the
> server it
> fails for unknown reasons. Does that work for you?
I guess not :-(
nik at vertical:/usr/local/src/grass6_devel$ make htmldocs-single
(cd lib/ ; make cleandocs ; make htmldocs-single)
make[1]: Entering directory `/usr/local/src/grass6_devel/lib'
rm -rf ./latex ./html
make[1]: Leaving directory `/usr/local/src/grass6_devel/lib'
/bin/sh: line 0: type: doxygen: not found
ERROR: Install 'doxygen' software first (get from
http://www.doxygen.org)
make[1]: *** [checkdoxygen] Error 1
make: *** [htmldocs-single] Error 2
Kind regards, Nikos
