[GRASS-user] Rename multiple sqlite columns at once
Moritz Lennert mlennert at club.worldonline.be
Thu Nov 13 04:28:57 EST 2008
On 07/11/08 01:47, Nikos Alexandris wrote:
> On Fri, 2008-11-07 at 01:38 +0100, Moritz Lennert wrote:
>> You still use quotes:
>> tempcolumn="$tempcolumn\_tmp"
>> IIUC, the quotes will let the slash appear literally. So, just leave
>> out
>> the quotes as follows:
>> tempcolumn=$tempcolumn\_tmp
>> However, as you say your original script (in my modified form)
>> actually
>> worked, it just spit out a series of warnings. So it might be more
>> interesting to check upon these warnings. I only saw these with the
>> sqlite driver, not with dbf or postgresql, so we should try to find
>> out
>> what happens  with that driver.
>> Moritz
> Oh, sorry Moritz. Now I see. I am at your service :-) Tell me what/how
> to test?
Sorry, for not coming back on this earlier, but I think I found it now.
The error (which also appears in other drivers, at least dbf), is due to
the following line in v.db.renamecol:
oldcoltype="`db.describe -c table=$table database=$database\
		driver=$driver | grep $oldcol | cut -d':' -f3`"
If you have two columns with the name of the first a subset of the name
of the second (e.g. DATA and DATA2, or in the nc_spm_06 dataset's
comm_colleges map, CC_ and CC_NAME and CCL_ and CCL_ID), the grep in the
above line will find both lines and result in an invalid oldcoltype:
GRASS 6.4.svn (nc_spm_06):~ > db.describe -c table=test | grep CC_
Column 7: CC_:CHARACTER:8
Column 8: CC_NAME:CHARACTER:30
GRASS 6.4.svn (nc_spm_06):~ > db.describe -c table=test | grep CC_ |
cut -d':' -f3
CHARACTER
CHARACTER
GRASS 6.4.svn (nc_spm_06):~ > oldcoltype="`db.describe -c table=test |
grep CC_ |  cut -d':' -f3`"
GRASS 6.4.svn (nc_spm_06):~ > echo $oldcoltype
CHARACTER CHARACTER
Which then obviously leads to an error as 'CHARACTER CHARACTER' is not a
valid column type.
Can you confirm that this is the case for you as well ?
And actually this is not only a warning issue, but the column is lost
because of this !
I don't have the time right now to try to figure out a solution, but you
can either give it a try yourself, or file a bug report, and I'll get
back to it when I have time.
Moritz
