[GRASS-user] why v.patch -e produces cat column starting from 2?
Eric Patton epatton at nrcan.gc.ca
Thu Nov 13 11:40:46 EST 2008
Moritz Lennert-2 wrote:
>> ## What is the option "id" doing exactly?
> It identifies features not by the category numbers, but by their
> internal id's. All features have id's, not all features have categories,
> but if you do, you can find out the id's of certain features with the
> help of v.edit tool=select, but normally, you won't ever have to worry
> about id's.
I've added notes about the id parameter, as well as a hint about using the
v.edit tool=select to discover geometry feature ids to the v.category
manpage. r34275 for 7.0, and r34276 for 6.4.
~ Eric.
View this message in context: http://www.nabble.com/why-v.patch--e-produces-cat-column-starting-from-2--tp20454068p20482246.html
Sent from the Grass - Users mailing list archive at Nabble.com.
